Serial No.
TRIED.Same result its taking 67 for all employees
It’s tested with Demo Database, no need to any changes as it is you can write and you will get answer.
May be you did some customization, you can check this solution in Demo database.
see the result;
any mistake you can find ??
Yes Seema,
You did mistake.
See carefully screenshot and as it is write.
Thank You binesh for your valuable time and support …
error is showing in on employee list pages
when i debug error is showing on
Hello seema,
Could you please write code as it is i given you,
I used TempEmployee.Extension field instead of Total Absence (Base).
And you are getting this error because you forgot to set Temporary property Yes of variable TempEmployee.
Done…! Thank You It’s working fine.
