Hi, Just thought I’d share an example of how to send emails from navision using Microsoft CDO, since I had at bit of trouble finding one myself: // vars CDOMail - Automation: ‘Microsoft CDO for Windows 2000 Library’.Message // Setup your CDO connection. Not sure all are required… CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/sendusing’).Value := 2; // cdoSendUsingPort CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/smtpauthenticate’).Value := 1; // cdoBasic CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/smtpserver’).Value := ‘smtp.yourserver.com’; CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/sendusername’).Value := ‘User’; CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/sendpassword’).Value := ‘Pass’; CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/smtpserverport’).Value := 25; CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/smtpusessl’).Value := FALSE; CDOMail.Configuration.Fields.Item(‘http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout’).Value := 60; CDOMail.Configuration.Fields.Update; // Setup your email CDOMail.“To” := ‘receipt@domain.com’; CDOMail.From := ‘sender@domain.com’; CDOMail.Subject := ‘Test mail from navision’; CDOMail.TextBody := ‘Hello world…’; CDOMail.Send; this is tested on MBS Navision 3.70 on winXP sp2 and it works. Just remember that the sender email has to be trusted by the smtp server. Had me fooled for a while… [:)] please post any comments or thoughts you might have.
