Sending Email Attachment through Batch
Hello
I am using Axapta 3.0 and I have been trying with no success to send an email with an attachment through batch. It fails to attach file. I am using the sysMailer class. It works fine interactive from menu. This is my code. I have also tried \server\folder\ path also with no success. I am running the batch process from my local pc. Thanks in advance for any help.
SysMailer mailer;
mailer = New SysMailer();
mailer.fromAddress(‘bob@xxxxx.com’);
mailer.fromName(‘Shipping Update’);
mailer.subject(“DAILY SHIPPING AND SALES PROGRESS”);
mailer.tos().add(‘bob@xxxxxx.com’);
mailer.body(“Please find attached Shipping Update” );
mailer.SMTPRelayServers().add(SysEmailParameters::find().SMTPRelayServerName,
SysEmailParameters::find().SMTPPortNumber,
SysEmailParameters::find().SMTPServerIPAddress,
SysEmailParameters::find().SMTPUserName,
SysEmailParameters::find().SMTPPassword);
mailer.attachments().add(“C:\DailyRecap.pdf”);
mailer.sendMail();
Hi Hudson,
I have done the same thing but still not getting the attachment mailed.I have made use of dialogue box in which system asks user to attach a file and then the file path as a string has been passed in mailer.attachments().add(“filepath”);. But system is showing the error “Error opening the file ''C:/Kanu.pdf”, The file is write-protected or in use".
Please help me if you can.
Thanks in advance.
Hi Kannu,
I have not worked with Axapta for over a year now, but from what I can remember, I was not able to get the batch job to send an attachment. I think my error was it could never find the file. At least you batch job seems to find the file. I was able to run the program and send and attachment by creating a menu option and running interactively but could never get the batch to work. Because it was a batch job…I wasnt sure if the process to attach the document occured at the server causing my error of not finding the document. This probably doesnt help you much but I wanted to let you know what I knew.
Thanks Hudson!!! :slight_smile:
I will try out something else then…
