How can we send a mail through X++ ? My requirement is I want to send the mail picking the records from the table. i.e I want to display the records of a table in the mail (which should be sent through code)
Can anyone pls help me on this ?
This Job can help you brother. Here i building a html table string of all customers belonging to a customer group and sending it through smtp server. The mail client interprets the html of the message and display the customers in a table of records.
You can build the html table by merging with the records of your table and send the mail.
CustTable custTable;
System.Text.StringBuilder htmlTable;
SysMailer mailer;
htmlTable = new System.Text.StringBuilder();
htmlTable.Append(@" Blue Company Customers");
htmlTable.Append(@"
htmlTable.Append(”");
while select custTable where custtable.CustGroup == ‘AP’
htmlTable.Append("
htmlTable.Append("
"); htmlTable.Append(custTable.AccountNum); htmlTable.Append(" |
"); htmlTable.Append(custTable.NameAlias); htmlTable.Append(" |
mailer = new SysMailer();
//building mail details
mailer.htmlBody(htmlTable.ToString());
mailer.subject(“Automated Mail - Customers”);
mailer.fromAddress(“Axapta@bluecompany.com”);
mailer.tos().appendAddress(“sayeed@bluecompany.com”);
// Setting SMTP details
mailer.SMTPRelayServer(“192.168.4.67”,87,“AXMail”,“1234”,false);
// Sending Mail
mailer.sendMail();
Thanks for ur code Sayeed.
Actually I am using an E-mail template ,so my requirement is to use that template where I will have some static text and a parameter.
For that parameter I need to pass table records (these records should be displayed in the mail in tabular form) through the code and send the mail.
Can u pls suggest me on this?
If you have a standard DAX 2009 demo VPC, you can see a similar functionality working. This functionality combines setting up Email templates and alerts.
