Send selected records to report from form in Nav2009r2..
Dear Friends,
i am having problem while send the selected records to report parameter from form.
Task is I have a list form from sales header table. when select the multiple records in the form then i have a command button while click that button action is status need to change & print lables for all the selected records.
Problem is: when click on the button status is changing for all the selected records. & lable is printing suppurately.
ex: suppose i have selected 5 records report printing on 5 times means individual files (PDF) are creating. i need 5 pages need create in one file.
Actual Question is How to send multiple records to report parameter.
Written Code on Command Button on push Trigger:
sales header1 : is loc variable for command button(Record : Sales Header)
"Order Paper" : is global variable (Report : Order Paper)
CurrForm.SETSELECTIONFILTER(“sales header1”);
WITH “sales header1” DO
IF FINDSET THEN
REPEAT
IF “Order Status”=“Order Status”:: Ordered THEN
“Order Status”:=“Order Status”:: Picked;
MODIFY;
COMMIT;
CLEAR(OrderPaper);
OrderPaper.GetOrderNo(“No.”,COUNT);
OrderPaper.RUN;
UNTIL NEXT=0;
CurrForm.UPDATE;
Can any one please look & suggest me for accurate result.
Thank & Best Regards,
Srinivas.
hi,
use this sample code as pattern.
Name	DataType	Subtype	Length
orderConfirm	Report	Order Confirmation
salesHeader	Record	Sales Header
filterParams	Text
counter	Integer
counter := 0;
salesHeader.SETRANGE("Document Type",salesHeader."Document Type"::Order);
salesHeader.FINDFIRST;
REPEAT
  IF filterParams <> '' THEN filterParams := filterParams + '|';
  filterParams := filterParams + salesHeader."No.";
  counter += 1;
UNTIL (salesHeader.NEXT = 0) OR (counter > 4);
salesHeader.SETFILTER("No.", filterParams);
orderConfirm.SETTABLEVIEW(salesHeader);
orderConfirm.RUN;
did it work?
Hi Jonathan,
Ya it’s working fine… Thanks
