Has anyone done anything to enable users to highlight and select multiple tracking lines from the Item Tracking form. It seem that Attain would have incorporated this in the application.[^]
No. But it should be possible since You in C/AL-code can detect which lines that are marked and then build a function that insert these serial/lot-numbers in the table Item Tracking Line where You came from.
Tried that with the SetSelectionFilter but was not able to detect the selected lines and thoughts about what may be wrong
Did you see the last line in the help about SetSelectionFilter ? Comments If either all or no records are selected, marks will not be used. could this be the reason ? I used the function several times and I had no problems with it. Francis
