In Req’option form am taking a Checkbox field , if i select tht one , the field shd appear in the report in its Preview mode…
Plz help me in this Issue…
Regards
venu
Regards
venu
I suggest that you create two alternate header and body sections for this report, one Header/Body combination contains the field, the other does not.
In the OnPreSection of the sections you add the following code:
CurrReport.SHOWOUTPUT(BoolValue); // This one shows when checkmark is ticked
or
CurrReport.SHOWOUTPUT(NOT BoolValue); // This one shows when checkmark is not ticked
depending on which section to print under which condition.
