Select sum in X++
I am new to Axapta. I don’t not sure how to do a simple SQL select sum in X++, could any one help?
SELECT firstonly SUM(CLOSINGQTY)
FROM Table
WHERE Table.TransDate == _TransDate
&& (Table.ItemId == _itemId) ;
I want to return the ClosingQty using a function. Any resource I could refer to ?
Many Thanks!
Table table;
select sum(amountMST) from table where table.AccountNum == “1”;
first try to go through the basic documentation given by Microsoft for x++ development…
which will help you in understanding the things…
“All the best”…
Dear Kranthi, I refer to your post regularly.
I need a little help. Is it poosible to put select sum statement in a variable? like
a = select sum(field) where field = variable;
Pelase reply.
Hey,
select sum(CLOSINGQTY) where Table.Field = variable
a = Table.ClosingQty [total will be stored in the variable ‘a’]
Hi Naresh,
Thanks a ton.
