Select statement on fields
I would write a select like this at sql server:
select name, (select age from agetable where name=people.name) as age from people
I couldn’t write select like that with Axapta. Is it possible with axapta or not?
I tried that with no success:
select name, (select age from agetable where name=people.name).age from people
You definitely don’t need subqueries (which aren’t directly supported by AX), just use a join. This topic is covered in Development II, for instance.
Example:
select Name from people
    join Age from ageTable
    where ageTable.name == people.name;
info(strFmt("%1: %2", people.Name, ageTable.Age));
You can write the select statement as follows:
Select fiedname from table join fieldname2 from table 2 where table1.relatedfield == table2.relatedfield;
Note : The two tables must be related with one field.
Now the fields as per your query will be selected.
Now, you assisgn the selected values as
controlname.text = selectedfield.value;
Meanwhile, the control you want to assign value should be set to " AutoDeclaration = Yes" in the property Sheet…
Actually I have three joins in my select command and there are more than one rows at my table which I want to add with subquery.
It seem I have to use group by clause for my select. I know distinct doesn’t supported too with Axapta… :slight_smile:
What are the three tables you are using and the rows you want to join
