select statement clausule not in AX 2012
hi guys,
Im trying to do this sentence (SQL) in AX, how to do that?
select …
WHERE InventLocationId not in (‘location1’,‘location3’,‘location8’)
Thanks.
Hello Rodolfo,
You can do the following:
select field1, field2
from tableA
where tableA.InventLocationId != “location1”
&& tableA.InventLocationId != “location3”
&& tableA.InventLocationId != “location8”;
If that is not an option, then you can use the Query Class and if needed iterate the result of the query. I the following example I am doing the query to the Table InventLocation.
Query query;
QueryRun qr;
QueryBuildRange qbr;
InventLocation inventLocation;
query = new Query();
query.addDataSource(tableNum(InventLocation));
qbr = query.dataSourceTable(tableNum(InventLocation)).addRange(fieldNum(InventLocation, InventLocationId));
qbr.value("!location1,!location3,!location8");
//qbr.value(SysQuery::valueNot(“location1”)); SysQuery::valueNot does not accept multiple values
qr = new QueryRun(query);
while(qr.next())
inventLocation = qr.get(tableNum(InventLocation));
info(inventLocation.InventLocationId);
its a good opinion, but the locations are not constants, it’s configurable
Then I think you could Read the setup and build a String to set the range
