select distinct itemno from itemledger entry table
i want distinct item no from item ledger entry table. i can get distinct item no from item table. but it loop all item and make slow. so, i want this from itemledger entry table.
how can i find this?
NAV does not have a “SELECT DISTINCT” concept. Your best bet is to use the item table. If you want to know whether it has a ledger entry or not you can add a FlowField to the Item table, or just do it with the simple calculation in code.
I have done this in the following way. this report will cacluate positive and negative adjustment value.
it show correct value. but it does not show first record. this is the problem.
help me.
OBJECT Report 50020 AdjustmentsTest
OBJECT-PROPERTIES
Date=17.01.12;
Time=14:31:00;
Modified=Yes;
Version List=Monir;
PROPERTIES
OnPreReport=BEGIN
IF PrintToExcel THEN
MakeExcelInfo;
END;
OnPostReport=BEGIN
CreateExcelbook;
END;
DATAITEMS
{ PROPERTIES
DataItemTable=Table32;
DataItemTableView=SORTING(Item No.)
ORDER(Ascending)
WHERE(Item No.=FILTER(1…));
OnPreDataItem=BEGIN
IF( Barcode<>’’) THEN BEGIN
// Item.SETRANGE(Item.“No.”, Barcode) ;
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Item No.”, Barcode);
END;
IF( DocumentNo<>’’) THEN BEGIN
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Document No.”,DocumentNo) ;
END;
IF( Warehouse<>’’) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Item Ledger Entry”.“Location Code”, ‘=%1’, Warehouse) ;
// “Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Location Code”, Warehouse) ;
END;
IF(( Positive=TRUE) AND ( Negative=FALSE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1’,“Item Ledger Entry”.“Entry Type”::“Positive Adjmt.”);
END;
IF (( Positive=FALSE)AND ( Negative=TRUE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1’,“Item Ledger Entry”.“Entry Type”::“Negative Adjmt.”);
END;
IF (( Positive=TRUE)AND ( Negative=TRUE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1|=%2’,“Item Ledger Entry”.“Entry Type”::“Positive Adjmt.”,
END;
IF (( Positive=FALSE)AND ( Negative=FALSE)) THEN BEGIN
END;
// IF (“Negative Adjmt.” =TRUE) THEN BEGIN
// END;
“Item Ledger Entry”.SETCURRENTKEY(“Item Ledger Entry”.“Item No.”);
“Item Ledger Entry”.ASCENDING(TRUE) ;
//window.OPEN(’@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@’,intProgress);
// timProgress := TIME;
Number := “Item Ledger Entry”.COUNT;
END;
OnAfterGetRecord=BEGIN
// ItemBarcode:=“Item Ledger Entry”.“Item No.”;
CLEAR( FirstBarcode);
CLEAR( FirstLocationCode);
CLEAR( PreviousBarcode);
CLEAR( PreviousLocationCode);
CLEAR( CurrentBarcode);
CLEAR( CurrentLocationCode);
CLEAR(NextBarcode);
CLEAR( NextLocationCode);
IF “Item Ledger Entry”.FIND(’<’) THEN BEGIN
PreviousBarcode:= “Item Ledger Entry”.“Item No.” ;
PreviousLocationCode:=“Item Ledger Entry”.“Location Code”;
END;
IF “Item Ledger Entry”.FIND(’=’) THEN BEGIN
CurrentBarcode:= “Item Ledger Entry”.“Item No.” ;
CurrentLocationCode:=“Item Ledger Entry”.“Location Code”;
END;
IF “Item Ledger Entry”.FIND(’>’) THEN BEGIN
NextBarcode:= “Item Ledger Entry”.“Item No.” ;
NextLocationCode:=“Item Ledger Entry”.“Location Code”;
END;
IF( (NextBarcode= CurrentBarcode) AND ( NextLocationCode=CurrentLocationCode)) THEN BEGIN
CurrReport.SKIP;
END;
// LineCount:=LineCount+1;
// NoOfRecords:= “Item Ledger Entry”.COUNT;
// IF timProgress < TIME - 1000 THEN BEGIN // every second
// intProgress := ROUND( LineCount/ NoOfRecords * 10000,1);
// window.UPDATE;
// END;
END;
OnPostDataItem=BEGIN
// window.CLOSE;
END;
SECTIONS
{ PROPERTIES
SectionType=Header;
SectionWidth=22650;
SectionHeight=846;
CONTROLS
{ 1000000010;Label ;1800 ;0 ;3150 ;423 ;HorzAlign=Left;
CaptionML=ENU=Negative/Positive }
{ 1000000011;Label ;5850 ;0 ;3900 ;423 ;HorzAlign=Left;
CaptionML=ENU=Barcode }
{ 1000000013;Label ;11100;0 ;2700 ;423 ;HorzAlign=Left;
CaptionML=ENU=Warehouse }
{ 1000000014;Label ;14550;0 ;3750 ;423 ;HorzAlign=Left;
CaptionML=ENU=Cost }
{ PROPERTIES
DataItemIndent=1;
DataItemTable=Table2000000026;
DataItemTableView=SORTING(Number)
ORDER(Ascending)
WHERE(Number=CONST(1));
DataItemVarName=;
OnPreDataItem=BEGIN
IF (Positive =TRUE) THEN BEGIN
PositiveItemLedger.RESET;
PositiveItemLedger.SETRANGE( PositiveItemLedger.“Item No.”, CurrentBarcode);
PositiveItemLedger.SETRANGE( PositiveItemLedger.“Document No.”,DocumentNo) ;
END;
PositiveItemLedger.SETFILTER( PositiveItemLedger.“Location Code”, ‘=%1’, Warehouse) ;
END;
IF( Positive=TRUE) THEN BEGIN
PositiveItemLedger.SETFILTER(“Entry Type”, ‘=%1’, PositiveItemLedger.“Entry Type”::“Positive Adjmt.”);
END;
PositiveItemLedger.SETCURRENTKEY( PositiveItemLedger.“Item No.”);
PositiveItemLedger.ASCENDING(TRUE) ;
“Value Entry”.SETRANGE(“Value Entry”.“Item No.”, CurrentBarcode);
END ELSE BEGIN
CurrReport.BREAK;
END;
END;
CLEAR(TotalPositiveQty);
CLEAR(ToWarehouse);
CLEAR(Unitcost);
WITH PositiveItemLedger DO BEGIN
IF( PositiveItemLedger.FIND(’-’) )THEN BEGIN
REPEAT
TotalPositiveQty:= TotalPositiveQty+ PositiveItemLedger.Quantity;
ToWarehouse:=PositiveItemLedger.“Location Code”;
UNTIL PositiveItemLedger.NEXT=0;
END;
END;
//“Value Entry”.SETRANGE(“Value Entry”.“Item No.”, CurrentBarcode);
// “Value Entry”.SETRANGE(“Value Entry”.“Item Ledger Entry No.”, “Item Ledger Entry”.“Entry No.”);
WITH “Value Entry” DO BEGIN
IF( “Value Entry”.FIND(’-’) )THEN BEGIN
REPEAT
Unitcost:= Unitcost+ “Value Entry”.“Cost Amount (Actual)”;
UNTIL “Value Entry”.NEXT=0;
END;
END;
END;
//IF PrintToExcel THEN
// MakeExcelDataBody;
END;
SECTIONS
{ PROPERTIES
SectionType=Body;
SectionWidth=22650;
SectionHeight=846;
OnPreSection=BEGIN
IF ( Positive=FALSE ) THEN BEGIN
CurrReport.SHOWOUTPUT(FALSE);
END ELSE BEGIN
CurrReport.SHOWOUTPUT(TotalPositiveQty>0);
END;
END;
CONTROLS
{ 1000000000;TextBox;1650 ;0 ;3300 ;423 ;HorzAlign=Left;
SourceExpr=TotalPositiveQty }
{ 1000000001;TextBox;5700 ;0 ;4050 ;423 ;HorzAlign=Left;
SourceExpr=“Item Ledger Entry”.“Item No.” }
{ 1000000002;TextBox;11100;0 ;2700 ;423 ;HorzAlign=Left;
SourceExpr=ToWarehouse }
{ 1000000003;TextBox;14550;0 ;3750 ;423 ;HorzAlign=Left;
SourceExpr=Unitcost }
{ 1000000005;Label ;150 ;0 ;1500 ;423 ;HorzAlign=Left;
CaptionML=ENU=Pos. }
{ PROPERTIES
DataItemIndent=1;
ORDER(Ascending)
DataItemVarName=;
OnPreDataItem=BEGIN
IF ( Negative=TRUE ) THEN BEGIN
NegativeItemLedger.RESET;
NegativeItemLedger.SETRANGE( NegativeItemLedger.“Item No.”, CurrentBarcode);
NegativeItemLedger.SETRANGE( NegativeItemLedger.“Document No.”,DocumentNo) ;
END;
NegativeItemLedger.SETFILTER( NegativeItemLedger.“Location Code”, ‘=%1’, Warehouse) ;
END;
IF(Negative=TRUE) THEN BEGIN
NegativeItemLedger.SETFILTER(“Entry Type”, ‘=%1’, NegativeItemLedger.“Entry Type”::“Negative Adjmt.”);
END;
// END;
NegativeItemLedger.SETCURRENTKEY( NegativeItemLedger.“Item No.”);
NegativeItemLedger.ASCENDING(TRUE) ;
“Value Entry”.SETRANGE(“Value Entry”.“Item No.”,CurrentBarcode);
END ELSE BEGIN
CurrReport.BREAK;
END;
END;
CLEAR( TotalNegativeQty );
CLEAR(ToWarehouse);
&nbs
This piece of code will do the trick, although not really a select distinct
code based on “Item Ledger Entry”
setcurrentkey( “Item No.”);
if findset then
repeat
setrange( “Item No.”, “Item No.”);
… do what you got to do …
findlast;
setrange( “Item No.”);
unttil next = 0;
i am not clear about this code.
with “Item Ledger Entry” do begin
if findset then begin
repeat
until “Item Ledger Entry” .next=0;
end;
end;
http://dynamicsuser.net/forums/p/46482/234938.aspx
i think grouping is the best idea here.
