Security on a special field
Hi all! I need some ideas here: I have created a boolean field where some restrictions must be done. Only specic users ( at the management level) should be able to change that fileld. What options do I have for that??? Thanks
You could add a boolean to the user setup to give specific users the right to change that field. 1. Add boolean to user setup 2. At the onvalidate of the boolean with the restrictions, add code to check the user setup, and give error when the user does not have the right to change the field.
