[?]I need to secure some info in Navision. In the “Item Ledger Entry” Form I need to hide some cells in the Amount Field for the specified category of users. I can hide the string in that form, or I can hide the Amount column…but I need to hide only the cell - the intersection of string and column. Any thougts how to do that?[?]
[:D] You could use a control wich ‘value’ should be updated by the value of the field. So you can tell the sytem not to show the control depending on the user role … But seriously, never do that
Hi, If you are using SQL Database, try the “security filter” option on the permissions. Cheers,
