Hi guys i have one problem i make security filter to one user to see specified item
ex
I create user A to see item Sp in purchase order
I succeed to make this but the problem is
when another user add purchase order with another item category as item WA
it make problem to user A when he open in next time(because item category for last order not match value for security filter for user A)
why?
can i prevent this
are any one have solving to proplem please help me
Kindly explain in more detail
I will explain proplem from first
I have two useres
A
B
AND two itemes sp,wa
I need to assign role to user A to see item sp but not see wa(spare)
I need to assign role to user B to see item wa but not see sp(water)
if i make purchase order have sp item this is last record i added and his item category sp then user A can see order i make because last record added sp so user A
Can open purchase order form and browsing orderes
But proplem happen when user B open purchase order form . the purchase order form not open and give him error “you dont have permission to read item table”
because last record have sp item category code. how i solve this proplem
user A
have two roles
ALL
spare
ALL(have as following)
all table data one by one(without item table)
read insert modify execute
tabel 0 yes yes yes yes
form 0 yes yes yes yes
report 0 yes yes yes yes
spare role (have as following)
item yes yes yes yes item category code=sp
User B Have two roles
ALL
WATER
ALL(as following)
WATER(have as following)
item yes yes yes yes item category code=wa
how i solve this proplem(how to avoid last record not much security filter not affect to form of purchase order)
i need solve to proplem if possible
Set filter on OnOpen form to see orders which are created by same users…
Like user A can see only orders created by A only…
User B can see orders created by B only…
for this you have to padd USERID on creating of Order
OK good but i need to make indirect access to item table can you tell me how this found in this article http://www.navision-girl.com/2007/02/security-filter-record-level-security.html in point number 3
