Searching within Forms containing temporary data
Hi all, Am I right, that it is not possible to search (Ctrl+F) through a table form (Similar to Form 345), which contains temporary data? Or does anybody have a clue? Thanks Gunter
Correct, you can’t search through a temporary table, there is really nothing to search for. Normally the form is based on one record, and you populate fields with another. There are a number of tricks you can do to get around this though. If for example, the source table for your form is INTEGER, then you will probably have to create your own search function. If the Source table is the same as the temporary table, you can probably put a field or two on the form for searching. _________________________ David Singleton Navision Consultant since 1991 dmks22@home.com___________
