Screen freezes while creating barcode
The screen flickers, freezes and hangs for several minutes when barcodes are created in SO, PO and Item forms. Ant suggestions please?
Isn’t it simply a performance problem? Use Trace Parser to identify what’s responsible for the delay.
As you said It seems like performance problem. Enable the trace parse to exactly figure out where it is creating bottleneck to the system and why system behaving like slow.
Hi Rahul - Please may I request on guiding on enabling trace parce? thanks
A good starting point is Tools for monitoring performance [AX 2012] in AX documentation.
