Hello, something strange is happening here.
I’m getting an error in my production environment when I try to release a production order:
stacktrace:
I found this site that seemed applicable and started going through the steps. We have 6 machines set up for operation 80, all of which are for the correct site and have calendars. I tried turning off the scheduling parameters. I don’t think we’re doing finite scheduling - We don’t use AX to actually schedule our machines, we accomplish that though manual workflows. With nothing else to try, I decided to attempt to enable the logging - however, I didn’t want to enable logging in production, as lots of users are in there… so I refreshed our test environment and enabled logging there. However, when I attempted to reproduce the error in test, I got a different message:
It’s definitely related, but it occurs at an earlier point in the code, where we’re initializing the scheduling engine:
And no, before you ask, I don’t have the "Enable the hot-swapping of assemblies for each develpment session.’ checkbox checked in the Ax Server Configuration Utility. And the line about data at the root level being invalid is because I added this code to the PropUndScheduling.Run method right before it throws the error:
info(strFmt("%1",AifUtil::getClrErrorMessage()));
I think it’s failing on some sort of xml import or something? But I have no idea why live doesn’t have this problem. The tracing I turned on in Test isn’t doing anything but it might if I could get past this CLR error.
Anyway, I hope that was enough information. I would appreciate any attempts to help, or even just to explain what the scheduling engine is trying to do - maybe I can simply ignore this functionality and any errors it throws? We do not schedule our machines using Axapta.
