Scheduler HiFish
Does anybody have experience with this software? I’m using HiFish 1.2 for one of our customer and we have still a lot of problems as … When running ‘Chain Starter’ following a CommandLine Job, HiFish crashes. When running HiFish with ‘Timer Starter’. If you stop HiFish and restart it : HiFish tries to execute all the jobs he should have executed while it was stopped … and crashes again… If you have more than 15 jobs in your work area, you can back it up into a configuration file but when you want to reload it later … it doesn’t work ??? HiFish doesn’t crash but nothing is loaded !! … At the beginning, I wanted to use HiFish reading and writing directly into NF database (2.60.B with C/FRONT for 2.60.B installed) without success…
