I am working in a client server environment. Have been trying to save customer statement as pdf(Report.SAVEASPDF(… but report isn’t saving to the directory. I have tried other reports like the customer lists and it works well. When I use same parameters to run the report manually, it works well.
you need to create a temp file using the ServerTempfileName in the 3-Tier Automation Mgt. , save the report as pdf to teh server temp file and then use DownloadToFile for downloading the file to to the folder.
Thanks for your imputs. I have tried the above but still not saving. Every other report I have tried saves right but the Customer statement. I have tried the standard unedited Cronus Statement and its also unable to SAVE AS PDF.
Any other advise? Is there anyone who have been able to do this?
Thank you very much for your response. I deleted the CurrReport.Preview from both places but still unable to save. I am able to SAVE as pdf when I preview but not when I write a code to do that.
