Save Navision report as Text File
Hi, How can i save Navision report as plain text file?
You could install a Text Printer Driver that would output you report into a text file
What driver should i install? Where can I find the driver?
When I’ve installed that driver it was called “Generic / Text Only”. I believe it is a standard part of the Windows installation at least from Win 95 forward. You should be able to just go through the “add a new printer” wizard function, look up the text driver in the provided list, choose it, and install it.
That’s the one I have used a few years ago …
quote:
