The fields startdate and begindate has to be stored in the new table(50012).
The propertie omschrijving belongs to table 90. So what I did was in the designer of table 90 add this: design of table and then go to properties of table 90 and then added this:
You display a form (item list?) with a begin and end date.
You created a new table where you want to save the begin and end date.
Then you change in the relation properties of the “number” field in table 90!
And then you don’t understand where the data is? In which step did you add data?
And you didn’t do any code to support this.
But I really still have no idea, exactly what you are trying to achieve.
It looks like you are trying to create an “attribute” table to the item table, but not quite sure.
Can you explain?
Also when you ask questions, then please start by adding a bit more “context” to your description. Like in this case, then I don’t really think what you do (if I understood it), is the correct path. Understanding the “context” of the requirement, makes it easier to reply to you. But on the other hand, if the question is too long, or have too much text, then they may not even read it all.
I have created a new table and gave it number: 50012. This table I created because I want to have on FORM 36 some new properties like startdate and enddate. But FORM 36 use the table 90. But I can’ t Add properties to table 90. Because I don’t have license to edit that table. So I have created a new table 50012. And now I add the properties startdate and enddate in the from 36. But I want to link table 50012 to table 90 and that the new properties startdate and enddate in from 36 are been saved in the new table 50012. I hope it will be now more clear what I want to archieve. Thank you
Documentation()
OnInsert()
Item.GET("Parent Item No.");
OnModify()
OnDelete()
OnRename()
Parent Item No. - OnValidate()
Parent Item No. - OnLookup()
Line No. - OnValidate()
Line No. - OnLookup()
Type - OnValidate()
"No." := '';
"Variant Code" := '';
Type - OnLookup()
No. - OnValidate()
TESTFIELD(Type);
IF "No." = '' THEN
EXIT;
CASE Type OF
Type::Item:
BEGIN
Item.GET("No.");
Item.CALCFIELDS("Bill of Materials");
"Bill of Materials" := Item."Bill of Materials";
Description := Item.Description;
"Unit of Measure Code" := Item."Base Unit of Measure";
END;
Type::Resource:
BEGIN
Res.GET("No.");
"Bill of Materials" := FALSE;
Description := Res.Name;
"Unit of Measure Code" := Res."Base Unit of Measure";
END;
END;
No. - OnLookup()
Bill of Materials - OnValidate()
Bill of Materials - OnLookup()
Description - OnValidate()
Description - OnLookup()
Unit of Measure Code - OnValidate()
Unit of Measure Code - OnLookup()
Quantity per - OnValidate()
Quantity per - OnLookup()
Position - OnValidate()
Position - OnLookup()
Position 2 - OnValidate()
Position 2 - OnLookup()
Position 3 - OnValidate()
Position 3 - OnLookup()
Machine No. - OnValidate()
Machine No. - OnLookup()
Production Lead Time - OnValidate()
Production Lead Time - OnLookup()
BOM Description - OnValidate()
BOM Description - OnLookup()
Variant Code - OnValidate()
IF "Variant Code" = '' THEN
EXIT;
TESTFIELD(Type,Type::Item);
TESTFIELD("No.");
ItemVariant.GET("No.","Variant Code");
Description := ItemVariant.Description;
Variant Code - OnLookup()
Installed in Line No. - OnValidate()
IF "Installed in Line No." <> 0 THEN BEGIN
IF "Installed in Line No." = "Line No." THEN
ERROR(Text000,FIELDCAPTION("Installed in Line No."));
BOMComp.RESET;
BOMComp.SETRANGE("Parent Item No.","Parent Item No.");
BOMComp.SETRANGE(Type,BOMComp.Type::Item);
BOMComp.SETRANGE("Line No.","Installed in Line No.");
BOMComp.FIND('-');
BOMComp.TESTFIELD("Quantity per",1);
"Installed in Item No." := BOMComp."No.";
END ELSE
"Installed in Item No." := '';
Installed in Line No. - OnLookup()
BOMComp.RESET;
BOMComp.SETFILTER("Line No.",'<>%1',"Line No.");
CLEAR(BillOfMaterials);
BillOfMaterials.SETTABLEVIEW(BOMComp);
BillOfMaterials.EDITABLE(FALSE);
BillOfMaterials.LOOKUPMODE(TRUE);
IF BillOfMaterials.RUNMODAL = ACTION::LookupOK THEN BEGIN
BillOfMaterials.GETRECORD(BOMComp);
VALIDATE("Installed in Line No.",BOMComp."Line No.");
END;
Installed in Item No. - OnValidate()
IF "Installed in Item No." <> '' THEN BEGIN
BOMComp.RESET;
BOMComp.SETRANGE("No.","Installed in Item No.");
BOMComp.FIND('-');
END;
Installed in Item No. - OnLookup()
BOMComp.RESET;
BOMComp."No." := "Installed in Item No.";
END;
If you have access to see the C/AL code (that you copied to the post) of table 90, then you can also add new fields (in the 50000 to 99999 no. range). Do you have a partner or end-user development license?
Because adding the directly to the table would be 200% easier! Even if you succeed in getting the table 50012 to store the data, then your next tasks would be to retrieve the data when reading each table 90 record. Not to mention if you want to filter the BOM lines by your new fields! This is never going to be a good solution, even if you spent weeks programming it… Sorry. [:(]
If you still wanna go on with this “method” then you need to link your tables. That is not done by changing table 90 (which I assumed you didn’t permissions to change), but by adding the primary key of the table you want to link to in your new table.
The primary key of table 90 is Parent Item No. and Line No., so that’s the fields you need to add to table 50012 as its primary key. This will allow you to create two simple functions in table 36 and call them from form 36:
NEW FUNCTIONS in table 50012
GetDates(BOM,VAR StartDate,VAR EndDate)
// Called from OnAfterGetRecord in form 36
IF GET(BOM."Parent Item No.",BOM."Line No.") THEN BEGIN
StartDate := "Start Date";
EndDate := "End Date";
END;
SetDates(BOM,StartDate,EndDate)
// Called from OnValidate of start and end dates in form 36
"Parent Item No." := BOM."Parent Item No.";
"Line No." := BOM."Line No.";
"Start Date" := StartDate;
"End Date" := EndDate;
IF NOT MODIFY THEN
INSERT;
That will solve you show and modify, but not the filtering issue…
Documentation()
OnInsert()
END;
IF NOT MODIFY THEN
INSERT;
IF "No." = '' THEN BEGIN
BeginDate := xRec.BeginDate;
EndDate := xRec.EndDate;
MESSAGE('hallo');
END;
OnModify()
OnDelete()
OnRename()
test - OnValidate()
MESSAGE('hallo2');
test - OnLookup()
BeginDate - OnValidate()
BeginDate - OnLookup()
EndDate - OnValidate()
EndDate - OnLookup()
Subscription - OnValidate()
Subscription - OnLookup()
No. - OnValidate()
MESSAGE('hallo3');
No. - OnLookup()
GetDates(BOM : Record "BOM Component";VAR StartDate : Date;VAR EndDate : Date)
StartDate := "BeginDate";
EndDate := "EndDate";
END;
SetDates(BOM : Record "BOM Component";VAR StartDate : Date;VAR EndDate : Date)
BOM."Parent Item No." := BOM."Parent Item No.";
IF NOT MODIFY THEN
INSERT;
Documentation()
OnInsert()
END;
IF NOT MODIFY THEN
INSERT;
MESSAGE('hallo');
END;
OnModify()
OnDelete()
OnRename()
test - OnValidate()
MESSAGE('hallo2');
test - OnLookup()
No. - OnValidate()
MESSAGE('hallo3');
No. - OnLookup()
END;
Stuklijst."Parent Item No." := BOM."Parent Item No.";
Stuklijst."Line No." := BOM."Line No.";
"StartDate" := StartDate;
"EndDate" := EndDate;
IF NOT MODIFY THEN
INSERT;
and I have defined in globals a new recod Stuklijst that has table 90
Oke, and I add the two new functions in table 90 like this:
Documentation()
OnInsert()
OnModify()
OnDelete()
OnRename()
Type - OnValidate()
"No." := '';
Type - OnLookup()
No. - OnValidate()
TESTFIELD(Type);
IF "No." = '' THEN
EXIT;
CASE Type OF
Type::Item:
BEGIN
Item.GET("No.");
END;
Type::Resource:
BEGIN
Res.GET("No.");
END;
END;
ItemAddition.GetDates(xRec,ItemAddition.BeginDate,ItemAddition.EndDate);
ItemAddition.SetDates(xRec,ItemAddition.BeginDate,ItemAddition.EndDate);
No. - OnLookup()
EXIT;
TESTFIELD("No.");
BOMComp.RESET;
BOMComp.FIND('-');
END ELSE
BOMComp.RESET;
END;
BOMComp.RESET;
BOMComp.FIND('-');
END;
BOMComp.RESET;
END;
But If I go to form 36 and I want to add some new items: but then I get this error:
sorry my mistake. Ofcourse not in table 90. But in from 36, like this:
Documentation()
Form - OnInit()
Form - OnOpenForm()
Form - OnCloseForm()
Form - OnQueryCloseForm() : Boolean
Form - OnActivateForm()
Form - OnDeactivateForm()
Form - OnFindRecord(Which : Text[1024]) : Boolean
Form - OnNextRecord(Steps : Integer) : Integer
Form - OnAfterGetRecord()
Form - OnAfterGetCurrRecord()
Form - OnBeforePutRecord()
Form - OnNewRecord(BelowxRec : Boolean)
Form - OnInsertRecord(BelowxRec : Boolean) : Boolean
Form - OnModifyRecord() : Boolean
Form - OnDeleteRecord() : Boolean
Form - OnTimer()
Form - OnCreateHyperlink(VAR URL : Text[1024])
Form - OnHyperlink(URL : Text[1024])
SetRecFilters()
InputDateStart := ItemAddition.BeginDate;
InputDateEnd := ItemAddition.EndDate;
IF (TODAY >= ItemAddition.BeginDate) AND (TODAY <= ItemAddition.EndDate) THEN BEGIN
RecSalesHeaderQuote.FncCheckBOM('affoni');
END;
IF StartingDateFilter <> '' THEN
SETFILTER("Starting Date",ItemAddition.BeginDate, StartingDateFilter);
ELSE
SETRANGE("Starting Date");
But If I open Form 36 I get still the same error that ar two many fields were specified
