Is it possible to save the asp.net control value to ax 2012 directly without using any axboundfields
I have a requirement for selecting Hijri date using calender widget ,widget only works on asp.net textbox only
this textbox I cant use inside the axboundfield. I need to save the selected date to respective field in ax table.
is there any workaround for this scenario.
Thanks in advance.
Regards
