Save a BLOB from another database to a file
Hi! I want to save a BLOB from another database to a file. I attached a sample that shows how it can be done using VB and C/Front. It works fine, but I can’t make it work in C/Side. I suppose it’s because of the missing Variant data type. But maybe there’s another way to do it. Any Ideas? Here’s the sample code Michael
quote:
Originally posted by mweigandHere’s the sample code: Hi! I want to save a BLOB from another database to a file. I attached a sample that shows how it can be done using VB and C/Front. It works fine, but I can’t make it work in C/Side. I suppose it’s because of the missing Variant data type. But maybe there’s another way to do it. Any Ideas? Michael
Have you tried the standard import code used in Navision when for example importing pictures (blobs) into the employee Table ?? You can import different kind of file types into Navision.
