Sales&Receivable Report menu NAv 3.60
Attempting to modify the text which is to be displayed when “Reports” is selected from menu. Can change the text, but the actual Report Name is still displayed. Any fixes out there?
What’s Broken?
Hello, This appears to work in 3.70 but not in 3.60 - If you export Table 243 Report List from a clean 3.70 system, you can import this back into 3.60 and this will fix the problem. Worked OK here! [:D]
Thank you Edward, That did the trick All the best, Eric Brunton
