We have set up a sales order for an item. The sales order is a blanket sales order. The item’s standard cost has changed. Is there a way to edit the unit cost on the sales order and continue to use the same Sales order? Or is there a way that if I post on that same sales order that I can pick up the current standard cost and not the standard when I created the sales order? Rob
If you have not posted on that line (which you would not likely be doing on a blanket order) you can just type over either the item no. or the quantity, and I believe the line will refresh, picking up the current costing data. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
What Dave said is true. If you have designer rights you can also make the field editable. Bill Benefiel Manager of Information Systems Overhead Door Company billb@ohdindy.com (317) 842-7444 ext 117
