During the sales order creation i am facing the below.
After the “PICKING LIST REGISTRATION” in “PICK and PACK” tab step over in my sales order creation, The next step in same tab “Generate - Inter Company picking list , Packing slip” buttons are not enabled. I cant proceed further due to the issue.
I simply created a sales order by following the steps from MSDN. Started from the Sales order form. Is there anything that we have to check in any forms in SETUP.
if inter company setup is not there then you can go with normal sales order steps. Instead of going through MSDN … go through with AX 2012 material (Chapter 6), it will help you in detail to perform SO cycle.
