I wanted to confirm that, I am not able to directly produce the Sales Order to Production order. I need to select individual item from the Sales Line item and then from menubuttons besides them Inquires->Production.
Is this the way to generate Production Order from Sales order module? OR I can generate PO from directly SalesOrder?
If you are trying to produce ONE production order to cover multiple sales lines for different items the system will not do this.
If you are trying to fulfill one sales order then planning is the way. If your items are not on the planned production order list then look at the net requirements, you may have stock, then look at the item coverage settings and the coverage group settings to ascertain how the system is configured to react to supply and demand.
That means you are saying like, “there exists a production order only for single sales line item.”(one production order for one sales line item). Is this so?
I am really very much confused based on this term.
Go to Production and load a manual one. It is item centric with BOM and routing. Two sales lines for two different production items will be two production orders.
No you do not need to do all stages, it will do them for you. Also the parameters control the possible movements between stages.
Ending does however remove WIP cost it finally and cannot be reveresed.
A planned order can only be converted into an actual one. An actrual one you process against. Planned orders come from planning based upon demand/capacity/material requirements based upon an awful lot of settindgs.
