Hi Pranav, i have a related question. My balance sheet account structure set up as range of Main account from say 2000…3000 with dimensions
2000…3000 + Business Units (all) + Customers (all) + Items (all)
Now when I try to post the product receipt list, I have two accounts set up 1 for purchase expenditure - un-invoiced (2150) 2nd for Purchase Accrual (2950)
System is throwing a message the dimension combination you selected 2150-- is not valid
dimension combination you selected 2950-- is not valid.
2150 is set up as AP account type (balancesheet)
2950 is set up as WIP in P&L
I thought it’s not mandatory to select the dimension unless you have an advanced rule or something.
Dimensions are mandatory by default. In your case, dimensions are not updated in PO lines. Update it and it will post.
Secondly, on the COA structure, when we select segment, there we can do the setup for null dimension allowed. If allow null is checked then system will not throw any error.
So you need to do either of two:
Specify dimensions on PO lines - recommended
Activate allow null on dimensions - not recommended until accountant confirms
