I have one requirement. Sales discount of 10% should apply if transaction amount will be more than 10000/- in SO. How can I configure this discount setup in AX. This should work without Retail Module
Hi Narasimha,
Do you mean that each order line which has a value greater than 10,000 can have a 10% discount. Or do you mean if the total order value is greater than 10,000 then the whole order has a 10% discount?
If the second option, do you care if the discount is applied to each line, or once to the whole order?
