Sales Credit memo (Report 207)
in Sales Credit memo report (207), i want to add External document no field in the header area…but when i go to the designer and view section area… i cant see that field in the field menu… why ? i am working in a company which has Attain 3.7 installed.
The field menu will only show the available fields in your current dataitem, and the header section in the 207 report is using the PageLoop dataitem, which is based on the “integer” table (this table is a so called virtual table in Navision). You’ll have to add a new textbox (or copy an existing textbox), open the properties window of that new textbox, and modify the SourceExpr property to MemoHeader.“External Document No.” - that’ll be all. Saludos Nils
thanks
