Hi all! I have a customer using Navision Attain 3.6 and he needs to do consignment . How is it possible to do that?? Thanks RF
There has been some discussion in the past in this forum (search on consignment). The best answer will be situation dependent. Your solution will probably included one or more of the following: a) all the consignment items assigned to a separate location and/or b) all consignment items are assigned a zero inventory value and/or c) using a field such as Product Group or the particular Inventory Posting Group to designate consignment material You may need other identifiers or constraints as well, depending on your particular situation.
