How can I set up a safety margin for a particular warehouse in AX 2009? So once the MRP is running, AX wil create planned orders for this warehouse.
It is item-warehouse based. Dimension group needs item coverage set by warehouse, then go to the item and item coverage in teh setup button.
You cannot set a global safety margin that is quantity based by warehouse.
If you mean time based youcreate item specific coverage groups with this set and use this on each warehouse line in the item coverage setup for the item. Depends why you need it, you can build it in as transport time as well.
