Hello all,
I have created a reliable Async sys operation framework batch job and need to run the batch in particular AOS or batch groups. Any suggestions which parameter/method in the controller class drives this?
Hello all,
Hi Parthav,
Create a batch group and assigned the batch server for that batch group, this will make sure that it runs on the batch server.When you schedule the batch job, select the created batch group for it,it automatically run the batch server which setup at batch group level.
Below is the link to create batch group and assigned the particular batch server to it.
