Running Navision Via Hyperlink in Excel
I would like to be able to insert a Hyperlink in an Excel cell that will open a report or form in Navision. We are using Navision Financial 2.60. Can you tell me if this is possible, and if so how can it be done. Thank you
Hyperlink is a feature that is alvailable to clients/server (native?) higher than 3.0 So you have to change the client and server to 3.x and convert your database. It’s not necessary to update your database logic (tables, forms, reports…). This can remain at 2.60. We worked with 2.01 objects on SQL7.0 and 3.01b Clients, so im not shure what to do if you have a native database. There is only one more problem: the Helpsystem has canged between 2.x and 3.x from *.Hlp to *.Chm. So you you get the wrong help contents for the 3.x objects. Examples? … look here → http://www.navision.net/forum/topic.asp?TOPIC_ID=4027 Bye Stefan
Do I need Navision Application Sever to do this? Thank you
