Running Navision in several countries
We run Navision over Citrix Metaframe XP. However when we try to push it out onto our Czech Plant, we get a "Fin.htm already exists in ". Has anyone come across this problem, and if so , how did they get around it? Thanks
We had the same problem. The problem is that the client have a different Time Zone setting then the metaframe server. The solution is to either change the clients time zone or to change a parameter in the metaframeserver that makes the server ignore the clients setting.¨ Where this parameter is set on the server I don’t know. Perhaps someone else could help you there. Best regards Daniel
