Dear All,
Can someone suggest me how i can write a code for Running Balance i.e
Running Balance = Running Balance + Amount in a Form
Thanx in Advance
Dear All,
Thanx in Advance
Just have a look at Report 16566 .Here you can get idea for the above code.
Sir,
I am using a single table i.e Analysis View Entry.
I have created a new form i.e Employee Balance using table Analysis View Entry., In the Form i require a Running Balance Field.
Kindly Suggest
Look at the General Journal form that has a running total and a balance.
You should be able to restucture that code to give you a running balance
Sir,
I have doen the following:
Form - OnActivateForm()
decClosing:=0;
Form - OnAfterGetRecord()
decClosing:=decClosing+Amount ;
And have attached decClosing in Running Balance Field.
But in this case i am facing a Problem as when i am moving down the form, the Running Field Value keeps on Changing in place of being constant.
Kindly suggest.
