Running a CodeUnit as a service using the Application Server
Hi Guys,
I have a custom CodeUnit which when I run from the Object Designer, displays all available CodeUnits as a webpage to allow them to be interacted with as a webservice, works great.
When I close the Classic Client, it stops working. Reopen, hit Run, starts working again and so on …
My project requires it runs indefinitely regardless if the Object Designer / Classic Client is open, so presume I can use the application server to install it as a service to run in the background?
I have tried the following:
nassql.exe appservername=MyNAVService, NETTYPE=TCP, servername=dynamicsnav2009, database=“Demo Database NAV (6-0)”, company=“CRONUS International Ltd.”, nettype=tcp, startupparameter=“V1Posting”, objectcache=80000, installasservice
V1Posting being the name of the CodeUnit with an ID of 80000.
The service starts great, but it’s not running the CodeUnit / the webpage doesn’t display. Any ideas how I can achieve this?
NOTE: I haven’t made any changes to the V1Posting CodeUnit to accommodate a service which I’m guessing may be the problem.
As always any guidance appreciated. :slight_smile:
Which NAV Version are you using ?
Version here
startupparameter=“V1Posting” should be
startupparameter=“JOBQUEUE”
Then Job Queue needs to be setup.
Hi Pete,
have you added the link in the application management codeuint (1) ?
You need to add in a bit of code into
NASHandler(NASID : Text[260]) function to run your codeunit when nas logs in.
cheers,
Gabor
Fantastic!
Created a JOBQUEUE entry and added the CODEUNIT underneath the standard Mailer and hey presto!
I don’t know what I would do without this forum! [:D]
Great…keep learning…
Nice to read.
You are welcome.
At work we just use an old PentiumII pc and leave it running 24-7 with codeunit turned on.
It’s sole purpose is just to run the codeunit. It’s even on a backup power supply.
