A program is developed to create an excel file. In live server they are using Excel 2003 version.
I have added following code to save a particular column as ‘Text’ format. The live server is facing run time error on the following code. But the same code is running fine with excel 2010 version.
//Create Excel WorkBook and WorkSheet
xlsWorkBookCollection = xlsApplication.workbooks();
xlsWorkBook = xlsWorkBookCollection.add();
xlsWorkSheetCollection = xlsWorkBook.worksheets();
xlsWorkSheet = xlsWorkSheetCollection.itemFromNum(1);
xlsWorkSheet.name(cnlin_EmailLogging.ReportFilePrefix);
cells = xlsWorkSheet.cells();
// numberFormat ‘@’ is to insert data as Text
cells.range(‘E:E’).numberFormat(’@’);
The error is 'Error executing code: Wrong argument types in variable assignment.'
Is the issue with the excel version or my piece of code ? Please help.
Raghav.
