After preview in Role Center, it displays
"An error occurred during local report processing.
The Hidden expression used in text box ‘Quantity_SalesInvoiceLine’ returned a data type that is not valid.
The Hidden expression used in text box ‘Quantity_SalesInvoiceLine’ returned a data type that is not valid. "
I need your help, thanks.
Go to the Textbox and open properties an go to visibility property and see the code written. it look like there datatype mismatch. Please check it,
I added ‘Quantity_SalesInvoiceLineFormat’ under Visibility property and I have removed it. It working now but my output is not in accordance with my layout. Thank you.
My displays are not in accordance with layout.
