run codeunit in scheduled task
Hi everybody,
First post for me here so “Hello World!”.
I’m a newbie in Navision, I use 3.7 Client/Side in one of our client environment. We managed to script a codeunit that extracts several dataport in CSV files.
Now I’m looking for scheduling this codeunit. I saw many posts related to NAS but only one with a batch script, which is exactly what we needed: http://dynamicsuser.net/forums/p/10936/33846.aspx#33846
Now my problem is that the authentication used in the production server is Database Server Authentication, so I should use a similar logic in my command:
“C:\Program Files\Microsoft Business Solutions-Navision\Client\fin.exe” database=“C:\MyNavDB.fdb”,compaNavisionny=“MyCompany”, userID=user, pass=pass, object=codeunit, id=50500
But nor user (nor userid) seems to exist. In the post above, rchurchil used a id but it is a bit strange for me. Is it the name of the object? If yes how can Navision knows that it is a codeunit or any other object?
Any help on this wiill be highly appreciated.
NAS can only do windows authenication, so you need to change your sql to mixed mode. Add a windows user in nav. and then run the NAS has that windows user.
Thanks for your quick answer, I will use the windows authentication, because indeed I can’t log in as a database user
Now I still dont understand rchurchil’s command in his post (see original post above). He used an id=370auto. What is it? and iff it’s the codeunit name how Navision can understandit is a codeunit object?
I tried to do it with this command, I log in as my windows account but then nothing happened:
“C:\Program Files\Microsoft Business Solutions-Navision\Client\fin.exe” id=50500,database=“C:\db.fdb”,nettype=TCP,company=“MyCompany”,ntauthentication=yes
My code unit is the object number 50500 and is name NAVEXTRACT
Thanks for you help
id=50500 means that Navision will use zup file 50500.ZUP
Database authentication should work too, because you are not running NAS.
From rchurchil’s post I understand that he added code to codeunit 1. I think he added if statement to CompanyOpen function:
IF USERID = ‘youruserid’ THEN CODEUNIT.RUN(…);
Why don’t you use Job Scheduler?
humm is there a job scheduler in Nav 3.7?
Yes it is, but you need to have special granule from service management area.
