Run Base form
Hi.
I have a task. I must build by runbase a form where I put a range( by date startdate stop date) and select a VendGroup. and when I clicked OK in info log it write my all PurchTable from Vendor’s from the vendgroup.
I don’t know How starts, need any help for this project
Take a look at AOT\Classes\Tutorial_RunbaseBatch, Where you find the dialog method wherein you can add your own dialog fields and write your business logic in Run method to process.
