Does anybody know a tool that makes it possible to run a NF codeunit from outside NF (e.g. in a delphi program)? If I understood it correctly, “cfront” only gives access to the NF tables… Jochen
You’re correct. You cannot run a CODEUNIT outside Navision Financials. Navision’s Webshop handles this using the message que. And what codeunit’s do you need? What are you trying to do? Best regards, Erik P. Ernst, webmaster Navision Online User Group
Hi Jochen! Well, you can not include a NF Codeunit into a Delphi-Programm, but there is a tool, which allows to launch NF-Objekts from the command-line. Visit the ExpandIT-Homepage www.expandit.com and look for the “Launch Utility” for further information. Regards, Jörg P.S.: This post is not an advertisement! Joerg A. Stryk Apollo-Optik, IT/ERP Edited by - stryk on 2001 Apr 04 14:57:10
Navision Solutions 3.00 will have this as standard. Meaning that you can create a shortcut directly to a report, customer card (with a specific customer i.e.). Best regards, Erik P. Ernst, webmaster Navision Online User Group
