Run a dataport from a dataport
Hi everybody, Is it possible to run a second dataport from the first one working witj the same file (both are for import) Thanks all
Why don’t you do a report instead that executes first dataport 1 (modal ofcourse) then executes dataport 2… Best regards/Med vänlig hälsning/Kveðja/Med venlig hilsen/Mit freundlichen Grüssen Johan Emilsson
That’s what I have done so far but I was wondering if there were other possibilities
Since dataports allow multibple dataitems (tables) couldn’t you just use that feature? Bill Benefiel Manager of Information Systems Overhead Door Company billb@ohdindy.com (317) 842-7444 ext 117
Another question, My file as ; as separator between fields The first field of each line is a number If 1 this is vendor information with 35 fields IF 2 this is vendor bank account information with only 6 fields It seems that Navision is unable to treat the case 2 BTW I have two different dataports Best regards
