If any body can help me … I will be very gratefull
I have a batch file named send.bat on C:\xxxx\send.bat
Can I run it from navision ? if yes what code i have to write …
if yes how i can code ?.. IF send.bat is exited or found
Thank you
Thank you
SHELL(‘C:\xxxx\send.bat’)
Yes, you can execute this via C/AL Code!
The easiest way is to use the SHELL command, e.g. SHELL(‘C:\xxxx\send.bat’)
Alternatively, you could use the “Windows Script Host” methods “Exec” or “Run” via Automation Server.
Hey Nuno, you were fast [H]
[:D]
thanks for Nino and jorg … you were both of you faster than i expected
thanks again [:)]
