When I crate a new report, I can view in in classic, but not in RTC.
I received the following error.
“Metadata for object of type report is in a failure state. This is by previos exception.”
If you did not create a RDL version of your report yet, just call the “Delete Layout” function in the tools menu while having the report designer Dataitems open.
Then close the designer and save the report.
Anyway you should consider converting your reports to RDL as the classic report versions will not be supported in the next releases.
