As usual, for each of the caption/field in classic report section, I will put the ‘DataSetFieldName’ (refer to image 1 attached). After that I will go to View → Layout to open up the RTC report designer, but some of the ‘DataSetFieldName’ i have added cannot be found when i browse through the ‘Fields (Dataset_Result)’ (refer to image 2 attached).
I have restarted the Navision service, but still the same.
Thanks in advance! [:D]
Nav version: 2009 SP1
Visual Studio version: 2008
