In Nav 2009 Classic Client, when running an account schedule with Analysis by Dimensions attached, the resulting form displays the Dimension Captions on the filtering tab.
When using Nav 2009 RTC client, the resulting Matrix only displays the field names e.g. ‘Dimension 1’, ‘Dimension 2’ etc.
when in the Matrix for the Account Schedule using the Filter ‘Limit Totals To’ the filter drop down shows ‘Dimension 1 Filter’ etc, whereas on the Classic Client, the Dimension Filter Tab shows the Dimension Caption name.
Sorry, only just seen the screen shot. No, it’s when you go to show matrix - then using the Limit Totals To - the drop down list only displays ‘Dimension 1 Filter … 2 Filter’ etc
