Hi ,
While running RTC I am getting following error
" You do not have permission to run the ‘Microsoft Dynamics NAV server’ system. Contact your system administrator to have your permission changed.
Kindly advice me to resolve this issue.
Thanks in advance.
rgds
dhananjay
is this the first time you are accessing server?
is ur domain user added in server database?
is nav server service running in server?
Nav server service is running.
Domian user is added in server DB
Is NAV and the DB server installed on different servers?
It is on same server.
use developer license upload it or save in database…
restart services …
Your license does not have the appropriate permissions. Contact your partner to get your license updated. If you are a partner then make sure you have an updated partner license and that you are not using a Cronus license.
