I get an error when disposing a fixed asset in the Fixed Asset G/L journal. The error is "Amount 2,785.26409 needs to be rounded in G/L Entry Entry No. =‘939582’. I suspect the 5 decimal places got in there when I was using a dataport to populate the journal in previous depreciation etries. However, I only see 2 decimal places when I look at the Fixed Asset ledger entries. I also tried another dataport with 5 decimal places to correct this but the dataport dropped the extra decimal places and the error didn’t change. Any ideas on why this is occuring and how it could be worked around? Right now Im stuck with disposed of fixed assets on my fixed asset schedule.
Hi Jeremiah ,
Try this
Go to the FA G/L Journal
Remove the Amount
Reenter it
If this doesn’y work, upload a photo of the error, journal entry, General Ledger setup
I’ll try to find a solution
Best Regards,
Hasitha
Verify the Solution that helped You !!
