Ahmedo
June 10, 2014, 12:26pm
#1
Hi
I just found one element of a node has been deleted in MorphX so is’t displaying in ax2012
whene i go to model AccountsReceivable i can’i see main menu common some thing in ax2012 client
whate i m looking for is there a way to roll back previous version of ax2012 and previous configuration of AOT in morphx
thank you
Where do you have the previous version? In version control? As exported models / model store? As model store database backup?
Ahmedo
June 10, 2014, 2:28pm
#3
I want to thank you for your answer and I’ve not understood you:
what i want is roll back to the standard in ax2012 (restore) i d’t have a menu ‘common’ of model “AccountsReceivable” displaying in menu node “AccountsReceivable” maybe it is deleted
How can’ i restore it?
Thank you
Do you mean deleting all customizations? Simply uninstall all modified models (+ compile/CIL/sync).
Ahmedo
June 11, 2014, 10:48am
#5
Thank you very much for your quick reply,and can you explain me how can i make it step by step?
And if i do this solution ,What is its effect on the whole
Best regards.
